FORTH on Propeller update?
I noticed a several interesting postings about FORTH for the propeller, but none in the last couple months. M. deSilva describes the FORTH projects as "failed" in his post of 2008-02-23. Have you guys stopped FORTHing around, or is work continuing but just not showing up in the forums?
I downloaded the binary from January 29 2008 from http://code.google.com/p/propellerforth/downloads/list
Also January 24 2008 http://code.google.com/p/spinforth/downloads/list
What was it about Janaury for FORTH on the the propeller?
There was mention that there were 4 FORTHs for the propeller, I cannot locate the other two forth versions. What conditions indicate the use of one over the others?
I am really interested in this device and FORTH is always the most fun for programming. But I only have a few hours to spent reading the forums. Is there a central location for discussion on using FORTH on the propeller for development and education? Is there a moderator or maintainer that is partial to FORTH?
Thanks!
Thanks!
http://cliffhacks.blogspot.com/search/label/propellerforth
I wish there were more Forth users with propeller, but apparently it's quite quiet atm..
Post Edited (JoannaK) : 6/2/2008 12:46:52 PM GMT
While the Forths that have been released are admirable efforts I have not been able to use them for anything serious yet. I really would like one that makes it easy to link to other Spin objects such as VGA and SD card drivers etc. I mean, there is more appeal to the Propeller than just the hardware, it is also in the Spin objects (some ingenious, all useful) that have been contributed. If you can't use them then you have to reinvent the wheel each time.
Also, I have found the Forth implementations neither fast nor compact and the serial driver which is the main user link to the Forth is limited. This isn't meant as a snipe at these Forths, it's just my reasons as to why I am not using them at present. Mind you, once I can get out of this insane hardware design cycle I would really love to sit down and tinker with a Forth, especially after my experience to date with the Propeller. I have very definite ideas on how this Forth should be but I am also aware that various compromises have to be made due to the limited memory.
One of my aims is to utilize SD memory as an integral part of the Forth system so that it holds the source code plus the headers and help files with the possibility of executing code from there as well. This would require a dedicated cog to handle the memory management and allocate virtual memory space but it's something similar to what I have done before and it's doable. The trick to making it fast is trying to keep the code in RAM which means it has to be composed of compact byte tokens, all headers and linkages etc are relegated to SD as that won't impact runtime speed.
I had originally used and modified Mike Green's FemtoBasic and found that easy to work with especially with the SD File system running and also since I could easily link in other objects easily. So that is how I want it to feel except in Forth and faster and of course more compact. So at the moment I'm "gonna get a round tuit" which is not good enough really. But you never know, I could put all the new hardware projects on hold for a week or two and concentrate on Forth, I know I could definitely use it myself.
In saying all this I must also say that I am getting quite used to Spin and don't mind it a bit. Of course Forth is an OS and not just a language though.
*Peter*
This is what I had in mind as well. Has anyone suggested a generic interface to spin objects from forth? For example, using a cog as a spin object librarian and pass results back to the tasks on other cogs?
IIRC Imagecraft C has this same limitation (no mixing with spin).
For personal Forth update.. Since last post I've done some coding with PropellerForth at Demoboard and it seems to be quite nice for 10kilobyte binary. It's not full system yet (no propeller side editor+videoscreen+keyboard+assembler) but it interacts ok via USB-serial port.
I have made some tool-words that are missing from PF 8.01. I have intention (time allowing) to make SEE ( small forth decompiler) and perhaps try to build nice compact inline-assembler.
( these 4 are done )
dump ( addr u -- )
.kindof ( xt -- ) ( what kind of definition)
.word ( xt -- ) ( print word name + info )
words ( -- ) ( Print available words )
Post Edited (JoannaK) : 6/4/2008 10:19:13 AM GMT
Note, this is first version asm syntax, so it may well change in time.
SI = SourceImmediate flag
ASM, = compiles assembler instructions line at a time
I also have WZ, WC WR and NR flags (and most common condition codes) defined, but those are not used in this small test.
Post Edited (JoannaK) : 6/10/2008 8:39:21 AM GMT
Has anybody started a Functional spec for a forth environment on the propeller?
Would this be interesting or useful?
At the moment I've become a bit preoccupied and thus need to slow down tinkering with PF for coule more weeks. But I'll be happy to help if there is any project on documenting. I'm considering releasing my Forth-words in source form (if anyone is interested), but some of them (SEE among others) needs serious rewrite.
Also PF does not hide the name of currently compilied word from search so if one tries simply to redefine word with same name it'll leads to recursion.. (Not according the standard)
Second point to note concerning stacks: in PF parameter stack grows upwards. Usually (though not mandatory) Forth stacks grow downwards.
spinforth has a printstack that is in the debug code in cog zero's spin program. It looks like it is invoked by trace.
