Question for the EE's among us..
Oldbitcollector (Jeff)
This is a Propeller/General Electronics question..
I'm playing with three servos.. Why does the following happen?
If I set the input voltage to 7.5 DC (walwart) I seem to over draw too much current and reboot the Prop.
If I set the input voltage to 9v DC (walwart) I seem to over draw much faster and reboot the Prop.
If I set the input voltage to 6v DC (walwart) everything works with power seemingly to spare.
This seems backwards to what I would have expected.. What's actually happening here?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
OBC
(Less current draw?)
OBC
There's nothing like a new idea and a warm soldering iron.
You need to specify what the current output for each of them as well at least what they say it should be able to provide) It should be in a ma rating. The ones you tried with a higher voltage may have a much smaller current rating. Under a load the voltage may drop a lot more than you would expect.
Do you have an extra cap placed near the connectors for the servos?
Robert
- Stephen
So I'm guessing it qualifies, despite my paying too much for it. [noparse]:)[/noparse]
It's my contention that we should standardize the DC voltages used by electronics
and wire new homes with dual wiring, one 110AC and another 6v-9v DC.
Stupid walwarts just suck juice, create heat, (that I have to pay AC to deal with)
and waste energy. (Sorry about the rant.. )
OBC
~~ dRu ~~
The Wall Warts may be cheap, but this behavior is normal for unregulated power supplies. Unloaded, they will have voltages 50% or more above the fully loaded voltage. This voltage drops rapidly with increasing load to near the fully loaded voltage, then stays near there to full load, then drops again with overload.
