SCribbler stall will not work — Parallax Forums
kitskubkitskub Posts: 1
edited 2008-06-02 18:52 in Robotics
When I upload anything with the stall sensor, it stops because it thinks the motors are stalling. It even does this when I pick it up and hold it as the motors run. Please help me.
    edited 2008-06-01 23:00
    Check that your batteries are fresh, at least 1.55V no load for alkaline AA's, or freshly charged NiMH. My Scribbler's stall sensor seemed undersensitive, it wouldn't trigger unless it was stopped going full speed. There's no software adjustment, it's a hardware trigger. I've seen other posts here with good info, look back a couple months.
    edited 2008-06-01 23:08
    Stephanie Lindsay can probably help you.
    http://forums.parallax.com/showthread.php?p=699869
  • JDJD Posts: 570
    This sounds like a Scribbler that needs to be sent in for testing.·Contact technical support at 888-997-8267 to set up an RMA; please have the following information available when calling:
    Customer Number
    Full Name
    Thank you
    Joshua Donelson
    www.parallax.com
