Lookdown and Strange Return Value — Parallax Forums
TJHJTJHJ Posts: 243
edited 2008-05-31 01:17 in Propeller 1
Ok So I am trying to get this thermocouple thing to work and my most recent thought is to use a lookdown table useing the known voltages.
But it does odd things. To create a search method of sorts it adds until it finds a match, not the best, but I am ok with a premant rounding up solution.
The table is very large it has approx 1500 data points.
PUB Look(Vi) | Table
 Table := 0
 Table := Lookdown(Vi:0,0039,0079,0119,0158,0198,0238,0277,0317,0357,0397,0397,0437,0477......
 Repeat
    Vi := Vi+1
    If Table > 0
      Quit
Return Table-1
It works if I call Look(0037) or Look(37) It returns 1, as it should,or Look(0075) Gives 2.
But if I put in Look(0030) it returns 857. Or Look(0031) gives 82.
And Ideas what is going on here?
Thanks as always
TJ
    edited 2008-05-30 22:15
    This is a terrible way to search a table, especially one as large as this. I suggest you define your table using a DAT section. Assuming you've got values less than 32767, you could use one word for each entry and fill the last entry with $7FFF. You'd search it with
    PUB look(v) : i ' Note: i is always initialized to zero
       repeat while v > myTable[noparse][[/noparse]i++]
    The table starts with the first value greater or equal to v.
    edited 2008-05-30 22:40
    TJ,
    Where does the data in your table come from? If it's mathematically-defined, perhaps a formula (either continuous or piecewise continuous) would provide a more compact way to arrive at the desired result.
  • RaymanRayman Posts: 16,460
    edited 2008-05-31 00:49
    First, I don't think your first Lookdown statement does anything and can be removed.
    I bet it's finding your values 30, 31 in the table somewhere... Try examining V1 during the iterations to see what's happening...
    Who knows, you may have found a bug... Or, maybe theres a mistake in your table.
    Or, maybe the memory space for the table is being corrupted somehow...
    You might try a test look for the last entry in the table and see if that works right...
  • TJHJTJHJ Posts: 243
    edited 2008-05-31 00:56
    Here is the Calc program I came up with which I think is even worse.
    CON
    A0 = -0.0176004136860
    A1 =  0.0389212049750
    A2 = 0.0000185587700320
    A3 = -0.000000994575928740
    A4 = 0.000000000318409457190
    A5 = -0.000000000000560728448890
    A6 = 0.000000000000000560750590590
    A7 = -0.000000000000000000320207200030
    A8 = 0.0000000000000000000000971511471520
    A9 = -0.0000000000000000000000000121047212750
    OBJ
    F : "Float32"
    ADC : "CD_LTC1298"
    PUB Init'(AD1)
      f.Start
      'ADC.Start(AD1)
    PUB DEGC(V) |  VP2, VP3, VP4, VP5, VP6, VP7, VP8, VP9, V1, V2, V3, V4, V5, V6, V7, V8, V9, AI1, AI2, AI3, AI4, AI5, AI6, AI7, AI8, AI9
      'V := F.FFloat(Vin)   ' Convert V to Float
      VP2 := F.Pow(V, F.FFloat(2))
      VP3 := F.Pow(V, F.FFloat(3))
      VP4 := F.Pow(V, F.FFloat(4))
      VP5 := F.Pow(V, F.FFloat(5))
      VP6 := F.Pow(V, F.FFloat(6))
      VP7 := F.Pow(V, F.FFloat(7))
      VP8 := F.Pow(V, F.FFloat(8))
      VP9 := F.Pow(V, F.FFloat(9))
      V1 := F.FMul(A1, V)
      V2 := F.Fmul(A2, VP2)
      V3 := F.Fmul(A3, VP3)
      V4 := F.Fmul(A4, VP4)
      V5 := F.Fmul(A5, VP5)
      V6 := F.Fmul(A6, VP6)
      V7 := F.Fmul(A7, VP7)
      V8 := F.Fmul(A8, VP8)
      V9 := F.Fmul(A8, VP9)
      AI1 := F.FAdd(A0, V1)
      AI2 := F.Fadd(AI1, V2)
      AI3 := F.Fadd(AI2, V3)
      AI4 := F.Fadd(AI3, V4)
      AI5 := F.FAdd(AI4, V5)
      AI6 := F.Fadd(AI5, V6)
      AI7 := F.FAdd(AI6, V7)
      AI8 := F.Fadd(AI7, V8)
      AI9 := F.Fadd(AI8, V9)
      Return F.FRound(AI9)
    What Do you guys think?
    So I ended up creating the table to 1500 degrees, even though they limit out at accuracy at somewhere around 1350.
    Post Edited (TJHJ) : 5/31/2008 1:21:14 AM GMT
    Rayman said...
    It seems to me that it is finding values which contain 30, 31 ect. I counted out the 83 number and its 1231. Is this is how this should be working.
    Rayman said...
    Yeah sorry I have been expermenting and was dumping the 1st lookup value out to a screen just to see if it was finding something before the actuall seach began. Its not needed but I was useing it for examination. Thanks for the help.
    I hope it is not a bug, but on the upside I would know I am not insane.
    Thanks for all the help as always.
    TJ
