Using a Bluetooth RS232 serial adapter to program a BS2
Do any of you know if it·is possible to use a Bluetooth RS232 serial adapter such as the Firefly:
http://www.ipenabled.com/bluetooth-rs232.html
Instead of a serial cable to program a BoE mounted BS2? From the page:
Our Firefly pair replaces your serial RS232 cable with a Bluetooth Class 1 wireless connection up to 100 meters (330 feet) away. The Firefly Bluetooth RS232 Serial adapter consists of two Firefly devices that can be configured to make a wireless RS232 cable replacement or extender. Each Firefly contains a 2.4GHz RF ceramic chip antenna. Just plug in each Firefly, set the baud rate DIP switches, configure the signal jumpers, and you are connected.
Thanks in advance!
Without testing it there’s no way to be sure, however experience has taught us that unless the device has been designed to buffer and re-transmit the data locally, it would most likely be prone to failures for reasons of timing and re-transmission issues.
david cooke
Note none of these timing constraints exists for most "generic" RS-232 communication using Blue-tooth. These constraints absolutely DO exist if you want to PROGRAM a BS2 over blue-tooth.
This could be useful, but is a bit more complicated than simply adding some bluetooth hardware.
Oh, and regarding the Firefly -- that "No MODEM Control" phrase in the documentation page implies this would NOT work off-the-shelf.
