trying to fade on and off a bunch of LEDs...
I'm working on a lighting project where I want about 32 LEDs to fade randomly on and off. What I came up with is to wire one, two, or three LEDs, in parallel, to each I/O pin of my Stamp, and run the attached code. But the Stamp seems to get overloaded if more than maybe 20 LEDs are lit at once, and the script freezes and the LEDs just flash. I imagine I need more current but how can I get it and still fade?
I have a feeling I'm being a dunce here. Please forgive a newbie.
With this hookup you can dim and control the brightness of the LED. You can even add a cap to the base to smoth out the voltage to the LED making it look more smoth from dim to bright using pulse out.
D. A. Wreski
