Signal LED
Hi All,
··· I have 2 BS2's communicating on PIN 8. What I would like to do is put a LED on the line to see when traffic is being sent. Is this possible and if so can you tell me the connections I need to make?
·· Ken
·· Ken
I've done this, and it is shown that way for pulsout in one of the Parallax books I read, so serial should be the same.
If you want to put less load on the serial line, you could run it through a transistor.
