Lighting a bunch of LEDs-Do I need a resistor?
I have to light about 300 LEDs from a battery pack. If I cut the power from the battery (7.2V) down using a voltage regulator to 3.2V (low end of forward voltage for the LED) do I still need to use resistors?
The LEDs use 3.2V and 20mAh. If I can avoid the resistors, I won't be wasting valuable mA. The 7.2V batteries have 4400mAh. By my calculations, I should be able to light the LEDs for about 44 min.
4400mAh battery power
6000mAh LED current draw
(4400mAh/6000mAh) * 60 = 44 min
Thanks!
Dan
Thanks!
Dan
I thought that if I dropped the voltage, it would mean I wouldn't need reistors.
Using the formula: R= (Vs-Vl) / I
where Vs=Voltage supplied, Vl = voltage required by the LED and I is the mAh draw by the LED.
Using 7.2V as the supply and 3.2V as the voltage forward and 20mAh as the current needed.
R=(7.2-3.2)/0.020
R is 200
If I only supply 3.2V, the equation becomes:
(3.2-3.2)/0.020
R=0
Am I using messed up logic? I thought it made sense, but I've been wrong plenty of times
Thanks!
Dan
and voltage regulators waste juice, they convert some current into heat.
its better to just drive 2 leds with a current limiting resistor. [noparse]:)[/noparse]
I'll wire two·LEDs in parallel and calculate the resistor needed.·I just need to make up 150 pairs...yuk.
I appreciate all of your help,
Dan
·R= (7.2 - 3.2 - 3.2)/.020=40· --> next size up is 51
Chris I.
Post Edited (StarMan) : 5/28/2008 12:41:25 AM GMT
BTW: The next size up from 40 (5% values) is 43. However, use the "typical" or "maximum" forward voltage for this calculation, not the "minimum". It's best to start with a high resistor value and work your way down, until you measure the current level you're looking for.
Post Edited (Phil Pilgrim (PhiPi)) : 5/28/2008 2:10:55 AM GMT
Good thing I read this, I was about to go start wiring it up. In series it is!
Thanks again, I do appreciate it.
Dan
