How can i replace the basic stamp circuitry with the intention to make it cheap
Hello everybody,
I have a question: How can i replace the basic stamp circuitry with the intention to make it cheaper for mass production.
I'm thinking of using a common microcontroller, but wich one will do a good job?
Thank you!.
[noparse][[/noparse]Subject Added By Moderator]
Post Edited By Moderator (Chris Savage (Parallax)) : 5/27/2008 1:40:44 PM GMT
Thank you!.
http://www.parallax.com/Default.aspx?tabid=248
There are many types of micros available, and your particular situation will dictate which one. How much memory, #of IOs, PCB type, manufacturer, volume, die vs flash (one-time-programming vs multiple-time programming). PIC and EMC chips are popular and some of the cheapest. In large volumes, you can get a 4-bit processor with 20K memory and 4-6 IO lines for 5 cents on a die that has to be bonded to your PCB and connected. SMT packages add price, but are easier to assemble.
In short, MANY variables, many prices, but a Stamp Stunt-Double shouldn't cost over 15-20 cents in reasonable volumes(over 10,000). Even if you add lots of memory (for digitized sound or other apps), you'll only be in the 30-50 cents range.
