Speed control of AC motor
Is there a practical way to control the speed of an AC motor?· Example: A 120V single phase, single speed motor, such as one found on a table saw or router.· Could this be accomplished by varying the supply voltage, or the frequency?
Also What determines the direction of the motor?
Post Edited (agfa) : 5/26/2008 1:02:59 PM GMT
VFD's are simply an AC rectifier to turn AC to DC - PWM control over the DC line - Tank circuit (Includes Inductance from motor in calculations) to smooth out the DC Pulse. This is not a simple circuit and it has quite a bit of power. Very dangerous to work with for even an intermediate EE. I would recommend buying one and skip making it if you are not familiar with them. I am assuming this as you had to ask how to do this.
Also, I may need some clarification, I thought PWM refered to a DC duty cycle.· The VFDs I'm familiar with, if I understand correctly, output AC.
Post Edited (agfa) : 5/26/2008 2:09:18 PM GMT
Almost all commercially available VFD's are designed for 3-phase motors.
Very small 1-phase motors ( ceilling fans and the like) can be somewhat controlled by varying the voltage level applied to them.
For small projects use a DC motor fed from a rectifier circuit. Once you get to 1/2 HP or so, move to a 3-phase motor. Note that low horsepower VFDs can be fed by a 1-phase AC source.
· Also note, your table saw probably has traditional Ac motor but the router has a brushed, "universal" ·motor which actually can run quite nicely on DC.
Cheers,
Tom Sisk
http://www.siskconsult.com
