i need the program for the boe bot that lets it turn the ping left,right and forward .thengoes to the further distance .i tried down loading it but it would not let me.so if you cuold cuould you type it here
You need to find out why it would not download. Don't use unreliable equipment to experiment, you will never know why something does not work if you are using known faulty equipment.
Here's the Roaming With PING program as a message attachment both as a source program and a PDF (printing) file. Some web browsers will print a PDF file directly.
If you want to open and print the program without installing the Basic Stamp Editor, you need to associate the .bs2 extension with Notepad.exe. Save one of the programs to the computer (or a jumpdrive if you don't want anything saved on the computer you are using) and right click on it. You should get a dialog asking you to search the web for a program or giving your the option to select from a list. Choose select from a list and pick Notepad.exe. The .bs2 files are text files and will open and print in Notepad with no problems.
- Stephen
If you have problems downloading it, you need to be very specific about what happens, what error messages you're getting, etc. It may be that your computer is not set up properly to download zip files.
Post Edited (smartg) : 5/25/2008 11:43:45 PM GMT
- Stephen
- Stephen
