Microchip 24lc1025 — Parallax Forums
Microchip 24lc1025
William50William50 Posts: 22
edited 2008-05-29 11:37 in Propeller 1
I would like to use the Microchip 24lc1025 eeprom in my design.
Anyone have any experience with this IC?
Tnx.
    edited 2008-05-23 07:54
    Hello William,
    i did not test it.
    From the datasheet the organisation has the same pattern 24LC1025 128kx8 original 24LC256 32kx8
    So if the minimum supplyvoltage-level is 3.3V i think you can use it
    The Propbootprocess reads in only the first 32K. The rest can be accessed by I2C-routines
    best regards
    Stefan
  • LeonLeon Posts: 7,620
    edited 2008-05-23 09:03
    The smaller 25LC256 works OK on my board.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • PavelPavel Posts: 43
    edited 2008-05-23 17:11
    What exactly are you looking for? The chip works fine with Propeller, using the same supply. Make sure you read the datasheet regarding addressing (there are two separate blocks inside the chip) and don't forget that A2 pin must be tied to supply (otherwise the chip won't work). This also limits you to 4 24LC1025 on the same I2C bus. I have SDA pulled up via 10K to 3.3V (that's a must) but SCL I leave without a pull up and drive it completely.
  • nicolad76nicolad76 Posts: 164
    I use the 24FC1025 instead with a modified version of NS_eeprom_drv_011 and it works great.
