Need some tech savey advice about the PING))))
I will try and keep this short...I am building a motorized device using 3 PING))) units to follow me with my golf clubs on board.· Simple operation, look for me within a certain distance out front, and look to the left and right to see if I turned.· I have the devices (3 of them) wired and running into a BS2, which is fast enought to do the job.
Everything works well, except, the PING))) devices seem not to detect me (my body) very well.· The distances here are within 7 feet down to 2 feet.· However, standing in front of a PING))) at 3 to 4 feet, it will only see me about 50 percent of time. A piece of cardboard 1.5 feet square works very well at the 7 foot range down to the 2 foot mark, but I can't wear a piece of cardboard on my back while I play golf.
Question, has anyone been able to "soup up" the PING))) device to make it more sensitive, either by more transmit power, or receive power.· (just guessing here, probably not).· But it doesn't hurt to ask.· If this is not possible, could someone steer me to a more powerful PING))) device, that a Basic Stamp would run.··The golf cart, motors, and drivers come later.
Deno
Deno
That should improve your rover reliability without messy hardware changes.
www.fd.com.my
www.mercedes.com.my
Deno
what about you carrying a GPS, when you move you new coordinates get xmitted and it know where to move with a built in offset from your location, I think accuracy would be greater than the above mentioned methods.
I think the best solution would be roborealm. it can easily track a person indoor and out, and even calculate distance. the down side is you would need to always golf in a red shirt, or do recognition training at start up so it knew what (who) to track.
not trying to sound negative, just offering my opinion.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Thanks for all the responses..
Deno
