Ethernet Expansion Card Demo Coders Needed
All right gang. We've got the final prototypes complete and ready for demo coders.
I'm looking for individuals that have had experience writing code for the Hydra and have a firm understanding of computer networks (esp TCP/IP and UDP/IP)
The card is an SPI implementation of the W5100 from Wiznet. Check out the data sheet for the chip to get an idea of what you would be dealing with.
If your interested send me a resume to shanemavery at yahoo.com
What all can it do? Will it go into production? Who will be selling it?
·</Parallel Universe>
This will go into production very soon. These are the final prototypes. Once I have some people other than me to play with these (thus the call for demo coders) we will go into full production. Andre' can correct this if I'm wrong but I imagine you will be able to purchase these unit in the exact same place you currently purchase the SD storage card and the 512K SRAM card for the Hydra.
Here are some youtube clips.
Here I show off the PCB and ping the device - http://www.youtube.com/v/Z9KpC5MwcG4
This shows the SPI driver writing and reading a byte to the W5100 -http://www.youtube.com/v/VulcSSBJ6_I
A UDP write and read to the PC - http://www.youtube.com/v/b7exfoPJob0
Hydra WebServer - http://www.youtube.com/v/QupQJw0WlEE
TicTacToe on a local network - http://www.youtube.com/v/EqzG31wzOIE
Timothy D. Swieter
www.brilldea.com·- uOLED-IOC, RGB LEDs, TLC5940 driver PCB
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
You should do a demo for the new card (if you aren't already), savery has a few more sample units for demo coders still, but time is running out.
Andre'
Timothy D. Swieter
www.tdswieter.com
I am bringing my handwired Hydra and hope to finally test out the built-in network port. The Ethernet card sounds pretty cool.
Any estimate on cost yet and when the regular production cards might be ready?
Robert
Timothy D. Swieter
www.tdswieter.com
Andre'
To get your own MAC address is a bit of a hassle. In theory·the MAC address for all·Ethernet devices·should all be unique. I think you have to apply·to IEEE to get a range of addresses assigned to you.
you will never see it anywhere else.. [noparse]:)[/noparse]
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Timothy D. Swieter
www.tdswieter.com
Robert
Timothy D. Swieter
www.tdswieter.com
DS2502-E48 (48-Bit Node Address Chip)
www.maxim-ic.com/quick_view2.cfm/qv_pk/3748
search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=DS2502-E48%2B-ND
The device is expensive if you are planning to mass produce your product. The good thing about using 1-wire is that you can always decide to purchase an OUI from IEEE and use a cheaper 1-wire device to store your MAC address without having to redesign your PCB. I've also heard of people using cheap 1-wire silicon serial number devices to generate the last 3 bytes of the MAC address (this obviously only works if you have an OUI).
Any updates on the card you were making for the Hydra? It has been a while since I have checked in the this forum and I don't see another thread on this topic.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.tdswieter.com
Price $59.99
www.parallax.com/Store/Accessories/Communication/tabid/161/CategoryID/36/List/0/Level/a/ProductID/540/Default.aspx?SortField=ProductName%2cProductName
Aka: CosmicBob
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
