Unknown bytecode
I'm often getting the IDE-0025 error message "Unknown bytecode in the JEM file (dup_x2)". What does it mean? I'm compiling my java source code with the IDE, and upload it with the same tool. Also, this issue append between 2 System.out.println lines.
System.out.println ("Succesful");
System.out.println ("Next available byte " + memoryAddr);
I know that the "+" is not a good idea with the string, but it's only to load data on the MC24LC256, so this will run only one time, and then been replac with another programm.
So how can I know what is the issue with the bytecode, and how can I avoir that? It's not the first time I get the issue, but this time, I'm not able to get ride of it.
Jean-Marc
Jean-Marc
result from the usb connection. See this thread for a possible solution:
http://forums.parallax.com/showthread.php?p=656527
If you use a serial based board like the Javelin Demoboard it usually
means the compiler generated a bytecode not supported by the
javelin firmware. This could be due to some specific program construct.
Please post the code that generates these errors.
regards peter
I'm using a serial connection. I have update the code and it's now working, so I can't send you an sampe with the error, but I will send you something as soon as I get this error again.
JM
