Servo Speed
Hey,
· Is the fastest the right wheel can go on the boe-Bot 850 and the fastest the left wheel can go 650?
Could you do like 950 with out wrecking it...
Dan Taylor
Dan Taylor
According to the legendary Mike Green, however, for many continuous rotation servos, including the ones sold by Parallax, sending widths greater than 1700 and less 1300 doesn't get you going any "faster". In other words, while you shouldn't hurt anything, the actual effective "range" of your pulses is supposedly limited to ~1300-1700us range.
That said, the best way to find out -- experiment! If you get your servos moving much faster at 2000us than you did at 1700us then you've more range to play with.
Dan Taylor
comments.· I have a few servos, all from Parallax at one time or another, scarcely a fair sampling of what's out there marketed as continuous motion servos.· I don't think I got much faster movement with control pulses shorter than 1300us or longer than 1700us.· I suspect most of the control is within that range and the speed sort of plateaus outside that.· Your mileage may vary.
P.S. Thanks for posting!
Dan Taylor
a) larger wheels -- faster platform speed, less power, but could be quick and simple
b) getting a little more voltage to the servos (say 6-7 volts rather than 5)
c) getting the fastest regular servos you can, then hacking them to be continous rotation (regular servos have specs for time/rotation angle, i.e., if the servo spec says it will turn 60 degrees in .2 seconds at 6 volts, that's obviously slower than a servo that turn 60 degrees in .16 seconds at 6 volts).
d) at certain point, if speed/power is the issue, you may want to think about small DC motors rather than servos (but then you will have the added complexity of driving the motors -- servos have their "drivers" already built in).
Others with much more experience in using the myriad servos out there will (hopefully) have more to say on this.
