Need help with SX48
To All
·I am kind of new to the SX· micro controller and I am having trouble getting the SX48 to work.
·I would like to thank all of you for your posts, books magazine articles they have helped me quite a bit.
·I am switching from a SX28 to a SX48. I am having trouble getting input or out puts to work I had no problems with the SX28.
I am using an USB· SX-Key and a SX48 Proto Board.
I can get the program loaded I just can’t get any output or input.
What device settings would I need for the SX48 and is there anything else that is different from the SX28.
Thank you for your help
Bill
Bill
- Are you writing your program in SX/B (compiled BASIC) or in assembly?
- What are you using as your clock? Resonator, crystal, or internal?
- Some of the example assembly programs use low memory for the first couple of variables. This may not be valid for the SX48 as it has two extra 8-bit ports.
- What input/output do you expect?? Are there LED's connected, switches, etc. How is it wired?
- If you post your code that will help!
As ROBOT said, without your code posted it is difficult for any of us to help much; however, if it is I/O that is troubling you in moving from the SX28 to the SX48 then I suspect you have overlooked the differences in the M codes for setting up the direction (and other) I/O registers. The SX28 uses M=$0F and the SX48 uses M=$1F.
Cheers,
Peter (pjv)
Here is the rough test code.
DEVICE SX48 ‘ not sure what this should be.
InputA PIN RB.0 INPUT
OutputA PIN RC.2 OUTPUT
Main:
OutputA = InputB
Goto Main
Bill Z
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
I am now able to use inputs and outputs.
Bill Z
