RFID reader question
I have just bought a Parallax RFID reader and want to create a connection with VB.NET like in the following article:
http://www.code-magazine.com/article.aspx?quickid=0611061&page=2
I connect the reader according to the attachment to the PC.
When I start the application and hold a TAG to the reader nothing is happening.
Does anybody know where I can find the error? Should the red LED turn into green when holding a TAG, or is there another way to see if the scanner is reading?
I have 4 different TAG's which I tried for this, which were enclosed with the reader.
Can anybody help me with this?
bmp
249K
From what I remember of my toying with the RFID reader, you had to send it a signal to get ready to read. Have you done this?
Did you try reading the port through hyper terminal to determine if its a software vs hardware issue?
I'm sure i have used the correct pins, because the pinnumber is also written in the connector.
I have just tried to read it through the winndows hyperterminal, but it isn't receiving something, so i guess it is a hardware issue.
I didn't send a signal to the reader, but how can I send a signal to the reader? It has the following pins:
- VCC
- /ENABLE
- SOUT
- GND
Or do you mean I have to bring the /ENABLE pin low?
There is actually an application posted at the following link which may help you. The RFID Reader /ENABLE line must be LOW to read tags, but doesn’t automatically cause the LED to change color unless the application brings the /ENABLE line HIGH temporarily to disable continuous reads. Take care.
http://forums.parallax.com/showthread.php?p=727719
