Need a new set of eyes please.
Heres the setup: propnic, 4 position dip switch, I want to be able to set the mac and IP based on the dip switch settings(personal use only, not going to license some mac addresses). Maybe I am missing something, but my my mind this makes sense, compiles, but does not work....
The dips are connected to input on 1 side, and 3.3v through a 100 ohm resistor on the other side, if the dips are all set to 0 I can connect to 192.168.1.70, any other settings and all other ip's fail
What am I missing?
Jimmy
.. It keeps killing my brackets... All of the instances above are bracketed but I am to lazy to add spaces to all of them as I did the first line
DIRA[noparse][[/noparse]20..23] := %0000
Address := INA[noparse][[/noparse]20..23]
Case Address
0: ip_addr [noparse][[/noparse] 3 ] := 70
eth_mac [noparse][[/noparse] 5 ] := $01
1: ip_addr := 71
eth_mac := $02
2: ip_addr := 72
eth_mac := $03
3: ip_addr := 73
eth_mac := $04
4: ip_addr := 74
eth_mac := $05
5: ip_addr := 75
eth_mac := $06
6: ip_addr := 76
eth_mac := $07
7: ip_addr := 77
eth_mac := $08
8: ip_addr := 78
eth_mac := $09
9: ip_addr := 79
eth_mac := $10
10: ip_addr := 80
eth_mac := $11
11: ip_addr := 81
eth_mac := $12
12: ip_addr := 82
eth_mac := $13
13: ip_addr := 83
eth_mac := $14
14: ip_addr := 84
eth_mac := $15
15: ip_addr := 85
eth_mac := $16
cog:=ser.start(i_cs,i_sck,i_si,i_so,i_int,xtalout,@eth_mac,@ip_addr) ' Start tcp socket drver
ser.listen(port) ' listen for tcp connections on port
repeat
time.Pause1ms(10000)
!outa[noparse][[/noparse]0]
ser.str(string(CR,LF,"*SENSOR:"))
ser.dec(Address)
ser.str(string(",RH:42,TEMP:79,DEW:46*",CR,LF))
!outA[noparse][[/noparse]10]
outA[noparse][[/noparse]8] := ser.isConnected
DAT
eth_mac BYTE $96, $11, $22, $33, $44, $01
ip_addr BYTE 192, 168, 1, 70
ip_broadcast BYTE 192, 168, 1, 255
ip_gateway BYTE 192, 168, 1, 1
ip_dns BYTE 192, 168, 1, 1
port Byte 23
What am I missing?
Jimmy
Also, make sure you check 'driver_socket.spin' for the correct ordering of the ip configuration block (the ordering of the values must be exactly the same). The ip_broadcast value has been replaced with ip_subnet in recent releases. Subnet is extremely important if you are planning on using client mode to connect to hosts outside of your local subnet.
Funny you should say that, I was actually replacing the dips with a pin setup after I posted, thinking that could be it, I also added a bit of serial debugging code, I telnet in and I see ADDRESS:15<cr><lf>ADDRESS:15<cr><lf>.... so it is seeing the correct jumpers(I set them all to high), but no connection on 192,168,1,85, I set them all to low and I get ADDRESS:0<cr><lf> and a connection is able to be established on 192,168,1,70 I really dont understand what is happening
also, I updated the driver and did not realize they changed this, updated the code to reflect a subnet mask instead, thanks, but still no go
Jimmy
Also, I just noticed you use '$96, $11, $22, $33, $44, $01' as your mac address. I would highly recommend you keep the most significant byte $10 (the 'Private' OUI) because it won't conflict with assigned OUIs. The most significant byte ($96 in your case) has special meaning.
The $96 in your MAC address means: 'locally administered address, multicast mac address'. You definately don't want multicast, and locally administered could cause confusion in the future. So again, use $10, and you won't run into any issues regarding packet switching inside your subnet.
Take a look at en.wikipedia.org/wiki/MAC_address#Address_details for more information.
Harrison
0000000X
X: uni = 0, multi = 1
000000X0
X: Global = 0, Local = 1
96 is 10010110 - local admin, unicast
if for some reason I wanted to claim this was a globally unique MAC I would tell it that it is 94 is 10010100 - Global admin, unicast, but I wont lie [noparse]:)[/noparse]
AMX holds a solid connection when I originally found this bug and changed mac addresses , so I have been using this mac range for a while now
anyone else have any on the fly ip addr / mac addr code that they have lying around so I can compare notes?
Pete
You're totally right. I somehow read the bits backwards then forwards. I really shouldn't be posting when I'm tired...
Which version of the stack are you using? There may have been some weird bug in one of the older versions that I didn't catch till later. Very old versions didn't correctly stop the low level asm driver, which would cause problems if you were restarting the stack with new ip/mac parameters.
Post Edited (Harrison.) : 5/19/2008 2:31:58 AM GMT
BEWARE THE UNICODE [noparse]:)[/noparse]
Jimmy
places p20 in as the most significant bit (reverses order). I think you meant to use
Address := INA[noparse][[/noparse]23..20]
Jimmy
