Is this a CMU cam? Can I do good use of this in my boebot?
I found this from a toy that is like a karaoke with mike and this camera looking thing. I made the camera working which is connected to the whole thing. If someone could help me to get thing working with my boebot. dragging a cable is just fine I am just a beginner and have no idea about wireless stuff. thanks for the replies. -bert (aka noxnox)
The Pi Guy
Post Edited (RXleonard) : 5/18/2008 1:21:47 AM GMT
KCC 20H
That on the shinny silver thing on the back of the cam. what is NTSC? If you could point me to a diagram from which I could make to have an output video going to my TV it would be much appreciated.
I have no idea what voltage to apply to the supply leads, though, especially since it looks like the regulator has not been populated on the board. Therfore the supply voltage may be critical. If you have a variable-voltage power supply, start at 0V and work your way up slowly until you see a picture. Or, if you can remove the lens, there may be a part number on the sensor chip, which will give a clue as to the proper supply voltage — probably either 3.3V or 5V.
NTSC stands for "National Television System Committee" and refers to the baseband video output that is standard in the U.S. Baseband video is not modulated RF, though, and cannot be fed into the antenna terminal of a TV. If your TV or monitor has a yellow RCA (phono) socket labeled "video input", that's the right place to connect your camera's output.
Cameras like this are not compatible with the BASIC Stamp. Since this is no longer a BASIC Stamp question, perhaps the moderators could move this thread to the Sandbox.
Post Edited (Phil Pilgrim (PhiPi)) : 5/18/2008 6:33:30 AM GMT
P.S. Thanks again for your time.
