Servo rotates when turned on
Hello.
I'm using BS2 with parallax servos (continuous rotation and modified standard) and I'm afraid that I've stumbled onto something that will give me trouble unless I find a workaround.
The moment I turn on the board, the servo rotates a little bit independently of what the program is. I realize why this happens, but is there a way to make it NOT rotate?
How do people deal with this? If I'm building a robot with several servos, I don't want them to rotate the moment I turn my robot on... They should only act if I'm telling them to do so via program.
Please help!
Please help!
Other than that, there's not much you can do. You might do better with various digital servos since those might have a better controlled behavior on power up, but there's no guarantee.
Other things that might help include a pull down resistor of roughly 10K on the control pin of the servo. It might be that noise on the servo control pin before the BS2 initializes its I/O pin is causing the twitch.
Don't think this helps. The servo has been calibrated to 1.5ms and still twitches a little if Vdd is interrupted and connected back (same as start up).
10k Resistor between pin and servo produced the same result as w/o it. Unless I need to connect it somehow differently?
The Pi Guy
You may have misunderstood Mike's suggestion regarding a pulldown resistor. Such a resistor doesn't go between the pin and the servo, but between the pin, which is connected directly to the servo, and ground (Vss). This forces the servo to "see" a logic low while the Stamp is in reset. Otherwise, the pin, which floats during that time, could wander high, creating a phantom pulse.
PhilPi: This still doesn't work (I just tried) because it's connection of the servo to Vdd that makes it twitch, not the pin.
I LIKE PI: Sounds like a great idea, I'll probably go with this.
RX: It's not the program, it's the original high voltage that's being supplied to the motor. Since it's connected to Vdd, it's always on HIGH, but to operate it requires pulses. So it twitches, and then waits for PULSOUT.
My temporary workaround was to make the servos spin in the direction opposite to the twitch upon initialization, but it's not the way to go. I think the problem will be resolved with the transistor.
Thanks again, and consider this topic closed.
Post Edited (asptamer) : 5/18/2008 4:45:17 PM GMT
