I need help with program code — Parallax Forums
GooberGoober Posts: 1
edited 2008-05-17 01:44 in BASIC Stamp
I have a Halloween·prop that is a witch riding a broom.
I have a spot light that will come on and light her up. Under her dress is a fogger which puts fog out the end of the broom. Her head moves up & down, And back & forth. Her eyes are yellow LEDs that fade· off & on. Her arm goes up & down waving a wand which has an LED cluster on the end and they change colors. (Her head has A Scary Terry audio board that run the mouth and sound)
I'm using a prop-2 controller board and an RC-4 relay board for the relays to run the motors & lights. My problem is somewhere in the program code. I download the program but when activated the RC-4 card is not responding.
I'm running a ser cable from pin 15 to the ser pin on the RC-4 board.
This is what I want the prop to do:
modify_inline.gif pin 14, trigger sensor·to activate prop
pin·0, runs audio card for 60sec
then pin 15 runs relay board:
····· soptlight relay = K1 on for 60sec
····· motor relays = K2 on for 60sec
····· fogger relay = K3·on 60sec while cycling 10 times (4sec on & 2 sec off)
program will stay off for 60sec before resetting
Here's the program so far. If any one can see where or whats wrong Please let me know. Thanks
'···{$STAMP BS2}
'· ·{$PBASIC 2.5}
[noparse][[/noparse] I/O Definitions ]
Sio· · · · · · ·PIN· · ·15· · · · · · · · · · · ' No ULN, SETUP = Out
Trigger· · · · ·PIN· · ·14· · · · · · · · · · · ' SETUP = DN
Audio· · · · · ·PIN· · · 0· · · · · · · · · · · ' use OUT0 to ST audio bd
[noparse][[/noparse] Constants ]
IsOn· · · · · · CON· · ·1
IsOff· · · · · ·CON· · ·0
#SELECT $STAMP
· #CASE BS2, BS2E, BS2PE
· · T2400· · · ·CON· · ·396
· · T38K4· · · ·CON· · ·6
· #CASE BS2SX, BS2P
· · T2400· · · ·CON· · ·1021
· · T38K4· · · ·CON· · ·45
· #CASE BS2PX
· · T2400· · · ·CON· · ·1646
· · T38K4· · · ·CON· · ·84
#ENDSELECT
SevenBit· · · · CON· · ·$2000
Inverted· · · · CON· · ·$4000
Open· · · · · · CON· · ·$8000
Baud· · · · · · CON· · ·Open + T38K4· · · · · · ' B/R jumper is installed
[noparse][[/noparse] Variables ]
relays· · · · · VAR· · ·Byte
·spotLight· · · VAR· · ·relays.BIT0· · · · · · ·' K1
·motor· · · · · VAR· · ·relays.BIT1· · · · · · ·' K2
·fogger· · · · ·VAR· · ·relays.BIT2· · · · · · ·' K3
timer· · · · · ·VAR· · ·Byte· · · · · · · · · · ' for trigger debouncing
cycles· · · · · VAR· · ·Byte
[noparse][[/noparse] Initialization ]
Reset:
· OUTS = %00000000· · · · · · · · · · · · · · · ' clear pins
· DIRS = %00000001· · · · · · · · · · · · · · · ' make P0 an output
· relays = %0000
· SEROUT Sio, Baud, [noparse][[/noparse]"!!!!!!RC4", %00, "X"]· · ·' clear RC-4
· PAUSE 60000
[noparse][[/noparse] Program Code ]
Main:
· timer = 0· · · · · · · · · · · · · · · · · · ·' reset timer
· DO WHILE (timer < 100)· · · · · · · · · · · · ' wait for valid trigger
· · PAUSE 5· · · · · · · · · · · · · · · · · · ·' loop pad
· · timer = timer + 5 * Trigger· · · · · · · · ·' update timer value
· LOOP
· Audio = IsOn
· PAUSE 25
· Audio = IsOff
· spotlight = IsOn
· motor = IsOn
· GOSUB Update_RC4
· ' fogger cycling creates 60-second delay
· FOR cycles = 1 TO 10
· · fogger = IsOn
· · PAUSE 4000
· · GOSUB Update_RC4
· · fogger = IsOff
· · PAUSE 2000
· NEXT
· GOTO Reset· · · · · · · · · · · · · · · · · · ' reset everything
[noparse][[/noparse] Subroutines ]
' Assumes RC-4 A0 and A1 jumpers are removed
Update_RC4:
· SEROUT Sio, Baud, [noparse][[/noparse]"!RC4", %00, "S", relays]
· RETURN
    Do you have the baud switch set correctly? also if you just send commands to the rc4 what do you get? Start with simple code to turn on and off relays one at a time till you get that to work then expand your program.
    - Stephen
