Connection from Board of Education by soldering?
Dear All,
I have·finished a project building a device. But now, I have got a little problem. In my project I need to take the RESET button out side of the case of the device·.·Because, the RESET button is on the board, and the problem is the Board of Education will be inside of the case, but I need it outside beside·a keypad (which is placed outside of the case).·So, I figured out that I will solder two wires from the RESET button and put a switch between them·which I can place outside (please see the attached image).
But now I··am bit confused that·when I solder the wires, will the RESET button or surface of·Board be hampered by the heat of solder? Yes so, then can anyone give me better solution please? Or is there other alternative way·of taking RESET button outside?
You havnt stated which stamp you have, if a BS1 then pin 6 is the reset pin
One other thing, the BOE is really for development rather than a finished project, is the case you are building going to take a lot of knocks? the links in the breadboard may get dislodged if the case is dropped or roughly handled.
Post Edited (skylight) : 5/16/2008 6:14:11 PM GMT
www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/ProductID/121/Default.aspx?txtSearch=carrier+board&SortField=ProductName%2cProductName
- Stephen
