Building a charge controller with a BS2?
So im finishing up a project, it uses a 48 volt battery bank (4 x 12v AGM 70ah) and will be chargable by either solar or a DC power source if needed.
I was just wondering, since the BS2 is allready in there, if I could somehow use it to control the charging instead of·buying an additional (and expensive) charge controller.
The solar pannels will be outputting 79.2v, and the DC power source I could set to any voltage, but for simplicity, lets just say it will be 80v unless there is a better voltage to run it at.
The batteries need to see 58.8 volts for primary charging, and can take·up to 7A, and stop when the batteries reach at 57.6 volts.· Then output needs to drop to 54.8·volts at no more than·700 ma for the float, or storage charge. The solar pannels will only be able to push 1.75A anyway.
So I would either need a way for the stamp to read the voltage of the pack, or a series of comparators to trip at certain voltages.
What is beyond me, and I know it shouldnt be, is how to regulate the voltage down, and how to limit the current. Im pretty sure this is some basic stuff involving resistors, and im going to feel real stupid when I see the responses. Maybe its just too late to think, I dunno.
So, what would be the easiest way to get the stamp to read a voltage in the 50-60v range? ADC?
What would I need to do to take 80v and regulate it down to 58.8v @<7A? Will this same circuitry work for a far lower power source, like the solar cells?
So any ideas or leads would be very welcome.
I guess there would be two ways to do it, not that im entirely clear on how to do either.
1 Would be with PWM, I could use a transistor of some type (the part I dont know) and use a pulsout command to pulse it on \ off rapidly, reading the output voltage (another part I dont know) and increasing\decreasing the on time to get the voltage I want. I've got a few blanks there I will work on filling in.
The other way would be with a resistance setup. Basically I could just hook the high end to a pot, give it ground, and turn the pot until I got the voltage I wanted. Probably couldnt actually use a pot, but a set of resistors of the right value. Seems to me there would be a ton of power wasted in heat this way though. I also dont know how to limit the current in either design. hmmm... thats probably in Ohms law somehow... V=IR = I=V/R So theoretically increasing resistance would limit the current, but wouldnt that change the voltage? Ehhh thats where I always forget or get lost.
Still dont know the best way to feed the stamp the voltage signal...
Hope this helps,
Dave
