Timeout feature of FullDuplexSerial & Extended_FDSerial objects
According to the info for EXTENDED_FDSerial & FullDuplexSerial objects..
If the timeout functions are used ( e.g. rxtime(ms)) and a timeout occurs a -1 is sent back as a byte.
So, If I have a routine that reads these BYTES back in to make a STRING ( using the BYTE[noparse][[/noparse]@mystring][noparse][[/noparse]index] etc Commands) then ..
Q1) what does a -1 mean to my string?
I believe that bytes values from 1 to 256 are valid ( for strings) and a 0 is used for the terminator.
Q2) Should I check for a timeout ( i.e a -1) and abort the rest of routine for creating the string?
Regards
Dave M
Regards
Dave M
1) -1 is the value consisting of all one bits. When you store this in a byte, the value stored is 8 one bits which is also considered to be 255.
2) Whatever makes sense for your program. You could just stop, store a zero terminator and return what you have. You could use the ABORT statement to return to whatever point the caller wants.
EUREKA!
I think you have just solved my problem.
I did not mention the problem I am currently having.
I am displaying these "strings" on an LCD, Sometimes my LCD will display a strange character , but repeatedly the same character and according to the character set of my LCD it is character value 255!!!! ( i.e all 1's for the 8 bits)
When this happens I also get "OVERSPILLS" in my display, meaning the string is returned with the 255 character ( the result of the -1) as you mentioned , but no termination is applied ( when this happens) due to the logic in my code. So I think I MUST be getting TIME-OUT'S and then when I do all hell breaks loose in my display!
So Thanks mike!, I will now refine my routine to check for this timeout value and take appropriate action!
I do make sure that I terminate my strings correctly, but that only happens if I get at least 1 "PROPER" character returned by the serial function.
But now that leaves me with the reason I am getting timeouts in the first place!
Thanks heaps Mike!
regards
Dave M
