Stonehenge - A Robotic Digital Clock
Stonehenge is my latest and most certainly my most unusual robot project to date. It uses a CrustCrawler AX-12+ Smart Arm and a Parallax Propeller chip to display the current time. All the digits needed to display the time are located on cards positioned in a semi-circle around the left and right sides of the arm. The time itself is displayed in front of the arm. This gives the clock a "Stonehenge" like appearance. There are a total of 14 cards. Each card has two digits with one on each side.
A state machine (written in Spin) determines which card and which side is needed to display the time and then executes the necessary arm movements. It updates the time once a minute. Currently it displays the time in 12 hour format. With additional cards it’s possible to display an AM/PM indicator or use 24 hour format.·
Most of the project was constructed from foam board purchased from the local office supply store. The cards are 1 ¾ by 4 inches. Embedded in the bottom of each card are two Neodymium magnets. The magnets snap to heads of 4-40 screws that are mounted in the base. The magnet/screw scheme compensates for any small amount of error that inevitably occurs when gripping and moving the cards around.
I’ve posted a short video of Stonehenge in action on YouTube.
http://www.youtube.com/watch?v=pH0HLXnXljY
The video shows a time update from 12:09 to 12:10. It demonstrates all the basic movements needed to display the time. If you watch carefully you can see it execute the following movements.
Put Card in Display
Get Card from Display
Put Card in Storage
Get Card from Storage
Flip Card around
I’ll also post more details and source code for those that are interested on my web site shortly.
www.norrislabs.com
The angels have the phone box!
Steve Norris
Put Card in Display
Put Card in Storage
Flip Card around
www.norrislabs.com
Steve Norris
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
Searider
Good use of the magnets too!
Timothy D. Swieter
www.brilldea.com·- check out the uOLED-IOC, an I/O expansion for the uOLED-96-PROP
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
