EEPROM VERIFY ERROR on COM Port 5?
HI,
On a circuit board I have built ( and I have made a few of them so far) I am getting the "EEPROM VERIFY ERROR on COM Port 5" error
I have changed the eeprom ( 24LC256) to a another new one but I get the same error
It does say the the PROP CHIP is detected!
Q1) Does anyone know what this means?
thanks
Dave M
thanks
Dave M
Is the EEPROM wired correctly ?
Did you test the EEEPROM Vcc ?
Is working the code with Ctrl-F10 (loading it in RAM) ?
Seems that your eeprom is not recognized by the pchip.
Regards.
Alberto.
Another thing is to check the devmgmt or equivalent on the Mac. I found that trying to get the FT232 usb chip to poll faster every 1ms slowed down everything else.
*Peter*
Thanks for the suggestions, but
I just found out what the problem is,
My two resistors for the i2C lines are 5K but my design ask's for 10K,
I will change this later and retest.
( My brother soldered this board together , so don't blame me
Sorry to waste anyone's time. :-(
Dave M
*Peter*
I remember you mentioning this before, But this is the thing that is different between the boards. I will test later today!
Also,
I am using a different "BRAND" of de-coupling capacitor for the EEPPROM ( to what I normally use) , its still marked "104" , could this be causing troubles?
Dave M
Ok, really you should check the basics like the power supply and all your connections, maybe you've got a bent pin on the eeprom?
Send us a diagram and/or pic.
*Peter*
http://www.jaycar.com.au/productView.asp?ID=RC5360&CATID=&keywords=0.1uf&SPECIAL=&form=KEYWORD&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
I do have others I got from RTNollet, he has the better ones and its these one I normally use..
Sorry but I don't have any manufacturers part numbers for these.
Dave M
I do get EEPROM verify errors at times but I think it's related to timeouts. I will investigate a little further on this matter and post my findings.
*Peter*
you can stop laughing now ! :-(
I changed the resistors to 10 K and still made no difference, ( and just for you pete, i made sure I placed the resistors in the right way!!!! , i.e polarity
If this is a timing issue where does this occur? ( propeller board? PC?,
I have been loading code many times in all day on other boards without this error.
I checked the rest of the board and its all the same as the other one I made, I have changed the eeprom, I have changed the Prop chip.
I can load in the spin code to RAM and this works.
Dave M
