Basic stamp and electronic speed controller (ESC)
I have some code that I originally wrote to controller the Parallax servo (which works great) and then grabbed a traxxas servo and tested it there (again works great). Now, and from the same RC car as I got the Traxxas servo, I'm trying to control the ESC. All I get is wide open reverse and the range that original would fully move the servo full range seems to have no effect at all.
Any thoughts on what I could be doing wrong or what else I may need to add to my circuit or code to fix this?
Brian
Brian
Have you connected the BS2's 'ground' (Vss) signal to the ESC?
I'm pretty sure these ESCs are using PWM to control the speed. Anyways, the only way I could get any change in frequency was to add larger and larger delays in between each pulsout, but I'm thinking that is only because after you don't pulse out for long enough time the ESC stops the motor.
Just some speculation on my side, I don't know what I'm doing or wouldn't need help [noparse]:D[/noparse]
If the numbers below were true for this ESC then I would expect the RF receiver would have to be pulsing different lengths to control the steering vs the drive motors. I guess this is possible but seems like a bad design. I'll try putting the ESC into the steering output of the original receiver and see if it gets crazy or acts normal. I did try increasing my pulse widths though from around 1100 or whatever I found the servo extent to be to 3000 and still wide open reverse was all I ever saw. It's almost like any pulse is giving me wide open reverse and then no pulse shuts it off....just not making sense [noparse]:([/noparse]
Brian
Also, it was still only reverse and technically when I get this worked out I don't even want reverse, just forward hehe.
Brian
