SOLVED: Servo Controller Not Working?!
Probably around 6 months ago I ordered the Parallax Servo Controller and a Standard Servo. Everything was great and dandy, but at the time I did not have the money to continue with my project, so the controller when into a box.
Now it's 6 months later. I took the controller out of the box, and started to set it up. Everything seemed fine, and then I programmed my BS2 with the sample code provided from the Parallax product page in the PDF file. The servo didn't move (But it did go HOME). I checked to see if the DEBUG could read the version number of the controller. The controller responded just fine with the Version number, which told me the BAUD rate was set correctly. So I continued to experiment for about an hour and a half, but I still could get nothing.
Here's the code ended up with right before I quit:
I thought the controller might be shot, but the problem is the servos will still fight me if I try to move them while the power is on. This makes me suspect there are still PWM's going to the servos and the controller board must still be in working order... But the servos still will not change position their positions from center when sent the command from the BS2.
Should I just buy another servo controller and see if it works, or does anyone have an idea of what I might be doing wrong?
Post Edited (Tim1681) : 5/11/2008 7:47:19 PM GMT
' {$STAMP BS2} ' {$PBASIC 2.5} ch VAR Byte pw VAR Word ra VAR Byte Sdat CON 12 baud CON 396 ra = 7 DO pw = 600 SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", 11, ra, pw.LOWBYTE, pw.HIGHBYTE, CR] SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", 12, ra, pw.LOWBYTE, pw.HIGHBYTE, CR] PAUSE 500 pw = 200 SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", 11, ra, pw.LOWBYTE, pw.HIGHBYTE, CR] SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", 12, ra, pw.LOWBYTE, pw.HIGHBYTE, CR] PAUSE 500 LOOP
- Stephen
There is a JUMPER on the PSC board which is supposed to control the "Networking" feature by telling the IC whether the pins on the board are 0-16, or 17-32.
On my board, it does not matter if the JUMPER is in or not, the pins are always 17-32, which leads me to believe there is either a short or an open somewhere on the board which deals with the Networking Jumper.
