Netburner email problem
I am trying to send and email from my netburner.
I have a gmail account and have set Nb_varEV to smpt.gmail.com· along with valid entries· in the email address and password fields but always get the follwing error
DNS lookup of "smtp.gmail.com" FAILED
See Status Register variable for success (11) or failure (01)
the status register is always 07.
I have tried may variations of···smtp.gmail.com with www and http etc to no avail.
the other netburner features seem to work,·· FTP, TELNET, WEBPAGES
ANy ideas would be appreaciated.
Caught in the PropWash
Shifting to an outside mail server requires you to somehow and somewhere be logged in. Depending both on your existing LAN and ISP service, there are a lot of different senarios. Do you first require a PPPoE login or not?
The Netburner isn't a Parallax product, so you aren't going to get specific help with it here.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
Post Edited (Kramer) : 5/11/2008 7:59:45 AM GMT
http://lifehacker.com/software/email-apps/how-to-use-gmail-as-your-smtp-server-111166.php
might be of help.
- Stephen
Open a command prompt on the computer and type in the following:
NSLOOKUP.
Once the program is running and you see the ">" prompt, type in:
set type=mx
smtp.gmail.com
The final screen will look something like the following, depending on the routers and firewalls between you and the DNS server:
C:\WINDOWS>nslookup
DNS request timed out.
··· timeout was 2 seconds.
*** Can't find server name for address 192.168.1.1: Timed out
*** Can't find server name for address 192.168.1.150: Timed out
*** Default servers are not available
Default Server:· UnKnown
Address:· 192.168.1.1
> set type=mx
> smtp.gmail.com
Server:· UnKnown
Non-authoritative answer:
smtp.gmail.com· internet address = 72.14.205.109
> exit
C:\WINDOWS>
If you don't get back the address of gmail, it may vary from the one above due to multiple servers servicing gmail, then your problem is the DNS entry in the PINK. You will need to get with whoever manages your network to get a valid DNS.
I am working on getting the webpages to be seen from outside using port forwarding, but no sucess yet.
