First time here. Need help with project. L.e.d.s and sounds. Thanks.
To start off, thank you very much for attempting to help me. OK, here goes, I'm building a "PREDATOR COSTUME" and one project is to build the led display that the creature has on his arm, you know , when he destroys himself at the end. Well, I have 40 leds that I already configured into the position that I want them in. I've encased them in fiberglass resin so now the leads are sticking out from the bottom(READY TO CONNECT!). I want them to flash in different modes and I want sound when I press some buttons. What do I buy from PARALLAX to do this project????? Thank you very, very, very much !!!
How many of the LEDs have to light at the same time? This is important because all microprocessors have limits on how much
current they can supply at any given moment. Do you just want the LEDs to turn on and off or do you want to be able to dim them?
What do you know about microcontrollers? What do you know about electronics? What do you know about programming?
You will probably need some chips to drive the LEDs that Parallax doesn't sell. You will probably need some kind of sound player
from a manufacturer like Quadravox or Vinculum. If you get an MP3 player like Vinculum's, you'll need some kind of amplifier.
Out of the 40 leds, 20 will be just on and the other 20 will just flicker on and off some simultaneously, some not, no dimming.
I read a little about microcontrollers , but never worked with them. I bought the 500in1 project kit and done a couple of projects dealing with transistors, diodes , capacitors but thats the extent of my experience.
I know nothing about programming but I build my own computers and install windows and know how to go to bios and what not.
I was thinking of buying the Parallax Professional Development Board. It looks like it could handle a lot.
http://www.parallax.com/Store/Microcontrollers/BASICStampProgrammingKits/tabid/136/CategoryID/11/List/0/SortField/0/Level/a/ProductID/313/Default.aspx
Then you can run a simple program like this..
' {$STAMP BS2}
' {$PBASIC 2.5}
thePin········· VAR···· Nib············ ' pin 0 - 3
Setup:
· DIRA = %1111························· ' make LEDs output, low
Main:
· DO
··· FOR thePin = 0 TO 3················ ' loop through pins
····· TOGGLE thePin···················· ' toggle current pin
····· DEBUG HOME, BIN4 OUTA············ ' show on Debug
····· PAUSE 250························ ' short delay
··· NEXT
· LOOP································· ' repeat forever
· END
You will need to drive the leds with a transistor from Vin arrange them
so they give you a cool pattern and put a couple of 9 volt batteries
together so you have some power to drive them . Hide the Stamp in your clothes unless you can fit them in the box you made and go from there.....
you won't need it but when you run the code on your computor you can see how the LED will light
so you can get an ideas of how to wire them..
List of screens for making the image:
http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/Level/a/Default.aspx?SortField=ProductName,ProductName
A kit that allows you to make games on TV:
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/ProductID/467/Default.aspx?txtSearch=hydra+kit&SortField=ProductName,ProductName
If you still want to use the leds, the propeller kit is probably the best way to go. But, if you want to use a basic stamp, try using the BS2p-40 here:
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/CategoryID/9/List/0/SortField/0/Level/a/ProductID/8/Default.aspx
If you go with this option, make sure you get a programmer able to hold it. I'm pretty sure you can use it on the professional development board, and once you have it, you can get info on how to program it in the download section. Good luck!
