Where to get static control foam? [RESOLVED]
I need some static control foam, the type that IC's are mounted in when bought new.
I bought a roll off ebay a few months ago, the thickness was only 1/8 inch. I see that it's still available, but I prefer the thicker type.
Any ideas where to get this stuff?
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Post Edited (parts-man73) : 5/10/2008 2:36:32 AM GMT
Brian
http://www.elexp.com/ant_2asf.htm
Haven't seen 73 used in a bit [noparse];)[/noparse]
Best regards.
I had seen in in my mouser catalog, a 2'x3' 1/4" thick for $25 and thought it was pricey, sounds like it may be right in line though.
Brian
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=13864
Thank you both for your input!
