Toddler Rev B
Hello,
I have a Toddler which says Rev B on the board if that means anything
The board is different from the one shown here: http://www.parallax.com/dl/docs/books/edu/toddler.pdf
I connected the board to my computer via a USB-Serial cable (http://www.amazon.com/Belkin-SERIAL-PORT-ADAPTER-F5U409-CU/dp/B00009L7MI) it's designated as COM3
but the BASIC Stamp Editor 2.4 doesn't see the Stamp
Under loopback and echo there is a yes under each
When I try to run the code it says No Basic Stamps were found
What is the problem?
I connect it to the PC by first plugging in the cable to the board and then moving the power switch to position 2. Finally, I press Run.
I don't think it's the USB-Serial problem because it works with other serial devices.
Help would be appreciated.
·Right_Uderstanding, Attitude, Speech, Action, Livelihood, Effort, Concentration, and Awareness
