Demoboard users have you tried this?
I'm curious if any of the demoboard owners here have tried
to put the SD on the data-lines of the VGA head yet?
I'm going to take a shot at it this evening and see if it's
remotely possible to open some more I/O for you guys.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Post Edited (Oldbitcollector) : 5/8/2008 3:07:42 PM GMT
OBC
What I'm suggesting is the possibility of keeping this open for other things,
like maybe that PropGFX card that Baggers/Coley are working on,
and moving the four required SD connections to points on the VGA head.
I'm picturing a SD card with a male VGA plug, so no, not shared.
Something like I did here with the Atari joystick stuff..
obex.parallax.com/objects/87/
I'm betting we can tap the I/O on that head for SD and open
things up a little more for demoboard users.
Shame I gave the one I had away at a club raffle. [noparse]:)[/noparse] <GRIN>
I'll try this tonight and see if it can be done.
OBC
2 issues here.
Try and see how you make out, I'm curious now. Both if it works in the first place.... and if it does work, does it work reliably?
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
you'd have to choose lines that aren't, giving you non-sequential pins. Most, if not all code that I've seen though have had individual assignments for the SD lines, not a range value
Brian
Interestingly, leaving the TV resistors connected does not seem to affect VGA colors.
Not exacly the SD answer but at least a data point.
jazzed·... about·living in·http://en.wikipedia.org/wiki/Silicon_Valley
Traffic is slow at times, but Parallax orders·always get here fast 8)
The mouse jack (rarely used on my bench) is very accessible as long
as your application doesn't mind a couple pull-downs.
VGA<-->SD next...
OBC
of open pins from the VGA head on my Protoboard. At least I've located a couple
that might be useful from the PS2 plugs.
OBC
Also, the PS/2 are 10K pull-UP ( to 3V3) with 100R in series on DemoBoard and ProtoBoard.
There are two spare PS/2 pins unused which could be re-purposed for SD card use via a PS/2 plug. The few cables I've checked don't have those pins fitted or are not connected, so good if a keyboard or mouse is accidentally plugged-in, but would have to build a PS/2 cable for SD interfacing.
