Boardgame->Ideas wanted
I am thinking of making a board game using a perspex panel and QTouch sensors (touch, wheel and slider sensors).
I need ideas for a compelling game.
Thank you
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Stickers for sale
Building Blocks To The Propeller Chip
Post Edited (computer guy) : 5/8/2008 6:35:29 AM GMT
Thank you
Touch sensitive othello perhaps?
A modern take on the old etch a sketch?
Rather than a game how about a very neat Lighting console with dimmer sliders, first select the lamp you wish to control by tapping it,·then dim it with a slider, connected to a DMX controller the possibilities are endless, this could be a better input device than the current touchscreen devices, easier to clean for one, and the monitor display or topographic view of a stage for instance could be mounted beneath the perspex screen( if sensors are not affected by the monitor screen).
You can buy those neat looking virtual keyboard projectors and although they have their own sensing you may be able to incorporate one of those onto the perspex?
Post Edited (skylight) : 5/8/2008 10:48:05 AM GMT
http://www.khet.com/
http://en.wikipedia.org/wiki/Laser_Chess
That would be enough to make me grab one of these.. [noparse]:)[/noparse] Gets my vote.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Upper left [noparse]:)[/noparse]
Very Cool! Is it working? Demo video???
OBC
I am after a more multi player game though say 2-4 players.
So please keep the ideas coming.
Thank you
Basically you flick your finger up towards your opponent which releases a line like a virtual missile in that direction towards your "enemies" at the other end, you can send as many as you can with both hands at one time and then defend the lines coming towards you by touching them before they hit your side or goalmouth, bit·like a two way "missile command" game.
You could have different types of missile depending on the technique used when launching, for instance a higher scoring or indestructible missile could be sent with a more complicated touch at the expense of sending more with an easier sweeping technique.
I can imagine this to be a fast reaction sort of game that might be a good laugh at a party for instance.
Would need to be expanded on but a great start.
Thank you
Fairly cheap.
Thank you
The biggest OLED available is Sony's 11" screen. It's $2500. I think you need to set your sights on something slightly more practical.
PeterM
OBC
The board is 13 concentric hexagons (rings), lines drawn from angle vertexes to center (think pizza slices). Pieces move on a two dice throw: 1 die determines slice, 2nd die determines progress toward center. First player with 6 markers in center ring wins.
Rules:
All pieces in active (1st die) ‘slice’ must move to a total of 2nd die. Each marker must move every turn or is removed from play—imagine 5 markers in a slice; a roll of 1 means all except one marker in that slice are removed from the board (players choice). 2 markers in the same ring, of the same player form a block and neither player can move past, but movement rules still apply.
Players roll again on doubles
Markers in the center ring are safe and cannot be removed by above rules.
Adjust rules to suit!
