Non Working Parallax Protoboard — Parallax Forums
christopherchristopher Posts: 31
edited 2008-05-08 00:42 in Propeller 1
I seem to have fried 2 protoboards seem to be working with the propeller tool but won't run from ram and won't retain program in eeprom.
Is the main prop chip dead or otherwise ?
Thank You
Chris
  • RaymanRayman Posts: 16,378
    edited 2008-05-07 23:28
    try a simple toggle program without using the pll. the pll is the first thing to fry, typically...
    edited 2008-05-07 23:53
    Follow Raymond's advice, it does sound like you have damaged the PLL. What circuits are you connecting to the protoboard? Are any of them inductive (solenoid, motor,...)?
    Paul Baker
  • christopherchristopher Posts: 31
    I've been using the boards with no problems, this time both boards failed with interfacing a GPS and the GPio object. I used a ds275 to convert fron rs232 via a 1.0k resistor onto the prop.
    Chris
