Transistor Hell
This is driving me crazy. I am missing something. I'm using a BS1 to control a transistor (TIP32A) to switch +24vdc voltage. When I power up and run the sample program I get a constant 24v output from the transistor. I used the LED to indicate when the circuit to the transistor is active. If I pull the conection from the base, then there is no voltage from the transistor.
Is it possible to mix voltages in this manner? I've been reading everything I can get my hands on, fallowing the examples and am able to recreate them however, when I change the example to use mixed voltage I don't get the same results.
If you use a TIP31 instead (NPN), Ground its Emitter and place the load between +24 and the Collector, you'll be alright better off.
I've·amended this to·"better off" because the load is unspecified and the TIP31 isn't a high-beta transistor.· Depending, you may want to go with a Darlington amplifier.
Time·─ Space·─ Gravity·─ Darkness·─ Death
Post Edited (PJ Allen) : 5/8/2008 1:41:28 PM GMT
A through hole mosfet that can handel 60 amps and 24V digikey part # 497-3519-5-ND On resistance in the .01 ohm range.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
