Build me a stamp — Parallax Forums
Build me a stamp
maddogmaddog Posts: 10
edited 2008-06-06 21:05 in General Discussion
Hi looking for some one to build a controller for me. I want to use this on a race bike and change my ignition timming.
Can you use a stamp·to read inputs from a pickup coil A/C volts? This coil trips a S.C.R. in a controll box, I want to slow it down when the rate of change is to fast. Inputs from the pickup coil happen every time the crank shaft turns, and it can spin at a rate of·11500. RPM's When the crank turns at 6000 RPM's the input from the pickup coil is 100 per sec, and 116 per sec at 7000 RPM's anything much faster the stamp needs to slow the single down to the SCR. any one up to the task? Thanks
    edited 2008-05-07 14:00
    Your duplicate post in this forum has been deleted.
  • william chanwilliam chan Posts: 1,326
    edited 2008-05-07 19:14
    I think a Basic Stamp may be too slow for this project.
    Maybe an SX or Propeller, should be able to do it.
    www.fd.com.my
    www.mercedes.com.my
  • maddogmaddog Posts: 10
    edited 2008-05-08 01:28
    I have been told the stamp can read at 3000 times a sec, but then again I dont know. The stamp needs to read a a/c signal and recognize the rate of increased inputs, and when the rate is to fast or steep, it will slow down the tripping the scr. When I make dyno runs the rate of accelaration is constent around 1000rpm's per sec. If the rear tire brakes traction the rpm's spikes increasing the rate of inputs from the pickup coil, the stamp reads it and makes a change.·I really dont need to know it works, I want some one to build it for me. thanks
    edited 2008-05-08 01:37
    It is unlikely that someone would put the amount of work needed for this for free. Are you prepared to pay a substantial amount of money to someone for this?
    edited 2008-05-08 13:14
    Hi Mike YES I would be willing to pay for a working unit. I'm a shop teacher who teaches motorcycle repair, the eletronics class at the school has been trying to build this for me but I feel the more lines I have in the water the better chance of getting a fish. In my spare time I run a professional race team that is ranked 24th the nation. I will be willing to work with all comers and any ideas, my Q is how much and how long.
    edited 2008-05-08 13:26
    A/C isn't a problem - it can be rectified and limited to an appropriate input voltage.
    Using a Propeller IS a very good idea as it is by far the fastest at sampling the data. After all, what good is a racing machine with 2nd best hardware supporting it? It is all about speed, as usual.
    PLEASE CONSIDER the following:
    Do you want a quickly operational black box solution or the knowledge included therein?······
    ···················· Tropically,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
    edited 2008-05-08 16:18
    the box!
  • Agent420Agent420 Posts: 439
    edited 2008-05-08 17:28
    Just my 2 pence... I'm sure with some dev work this would be possible.· But Murphy has a habit of visitng when you're testing projects on expensive gear...· Consider what could go wrong and if any damage would occur.·
    Also, not knocking the Propeller, but if this is anything more than a learning project for yourself, you should highly consider some commercial alternatives for a tried & true device.· I see programmable low cost ignition controllers all the time in Elektor, EPE·et al.
    edited 2008-05-08 18:37
    There is no such device out as of now, there is one in the works, I'm trying to get my hands on one. From what I'm told the stamp is about $50.00 and the rest needed would not cost much more. If a opto isolator is used we can protect the rest of the board? I'm not to worry about the bike motor I have many.
  • jmalaysiajmalaysia Posts: 97
    edited 2008-05-09 02:51
    From what I have read, you are after a traction control device to retard timing and prevent wheel spin. If that is the case, a system DOES exist, and is in fact standard on an 08 Ninja ZX-10R. It is also available from Z-Fi for other bikes at about $1000 ea. The complexity of what you want to do is probably beyond what anyone here could do without having a complete bike and rider (as well as a passion for racing). In theory it is a simple project. In reality it would be a major trial and error project, with the end result being something you would want to be able to use with different engine and ignition combinations, meaning it would need to be easily modified to meet your future needs. It sounds like a pretty interesting project, but I doubt it will get done via a bulletin board or email.
    edited 2008-05-09 06:21
    The Propeller could actually cost less than a BasicStamp on a protoboard and provide you with space to add interface electrions. Having a much higher clock rate and 8 processors makes is far more appealing.
    Just because there is a commercial device out there, doesn't mean that one cannot explore improvements in both cost and design. A $1000USD device really justifies a lot of DIY. If it were $200USD, one might just buy it.
    edited 2008-05-09 10:42
    Kramer said...
    I certainly agree with you.· The main reason I suggested a commercial product is because the original poster wants a completed project, not looking to build himself.
    Just for example, check out Jaycar electronics (jaycar.com).· Search for 'ignition' - there are a couple of items there such as:
    #KC5442 - Programmable High Energy Ignition System· - $89.95
    This is Silicon Chip's most advanced and versatile ignition system yet and can be used on both two & four stroke engines. The system can be used simply to intercept and modify the factory ignition timing or turned into a stand alone ignition system with remapped timing, electronic coil control and anti-knock sensing. The unit will trigger from a range of sources including points, Hall effect sensors, optical sensors, or the 5 volt signal from the car's ECU. Timing can be mapped against engine load and RPM and adjusted in step as small as 0.5°.
    #KC5443 - Ignition Coil Driver· - $44.50
    Add this ignition coil driver to the KC-5442 Programmable Ignition System and you have a complete stand-alone ignition system that will trigger from a range of sources including points, Hall effect sensors, optical sensors, or the 5 volt signal from the car's ECU. The kit can be mounted close to the coil to minimise energy loss and the controller can be fitted inside the car. Kit includes PCB with overlay and all specified components.
    #KC5444 - Knock Sensor - $16.95
    Add this option to your KC-5442 Programmable High Energy Ignition system and the unit will automatically retard the ignition timing if knocking is detected. Ideal for high performance cars running high octane fuel. Requires a knock sensor which is cheaply available from most wreckers. Kit includes PCB with overlay and all specificed components.
    These all seem to be based on projects published in Silicon Chip.· You might also consider searching their site for 'ignition' as there are several other related projects.
    Those prices are low enough to consider for (almost) turn-key products.· Again, learning is one thing, but paying someone to develop and build a similar system would probably exceed that cost.
    Post Edited (Agent420) : 5/9/2008 5:55:59 PM GMT
    edited 2008-05-10 15:06
    Jaycar and the Aussies have really been the leaders in this field. They love to use electronics to tinker with automotive performance. I guess they have some much off road territory that they don't have to worry about being 'street legal'.
    A few years back, someone developed a NOX system with Parallax products that was quite adequate. I think there is still info in the Finished Projects section.
  • datacpsdatacps Posts: 139
    edited 2008-05-10 17:59
    jmalaysia is correct
    http://www.bazzazperformance.com/index.php?page=shop.browse&category_id=4&option=com_virtuemart&Itemid=26&vmcchk=1&Itemid=26
    maddog that is what you need. Why reinvent the wheel. You are a pro-team you should get the best made. Building one from scratch can be done it would take a little time and more than 1000 dollars to do it correctly. I would buy the one already made its going to save you so much time and money that way. Goodluck and if you get a chance PM your website or team pics of your race bikes ... Sounds like you have a lot of fun..
    edited 2008-05-10 18:35
    I think what I found was actually a fuel management TC system, but the end result could be the same.
    edited 2008-05-11 03:14
    we run carb's no fuel injection, the jaycar unit says their unit can be used to intercept and modify the factory ignition timing, I plan to order one. but its so chep compared to what I have been wating for, hard to believe. Thanks for the help but I will leave the door open on some one building me something else. My rider on the mile at 140 mph #24
    108 x 86 - 17K
    edited 2008-05-16 12:31
    Just an up date the students at the Mt. Pleasant Area Tech Center tried their controller on a simulator just the other day; it read the input but failed to modify it.
    edited 2008-05-16 12:37
    Was this their design or another?· What is meant by simulator - spice?·
    edited 2008-05-16 15:58
    Students used a sign generator, and it was their design.
    edited 2008-05-18 05:32
    Mt Pleasant Texas?? That's just down the road from me if so
    edited 2008-05-19 12:14
    Mt. Pleasant Michigan!
  • Eric REric R Posts: 225
    edited 2008-06-01 07:50
    A quick test for your electronics guys,
    hook the + lead of a .1uf tantalum capacitor to the pickup coil of the bike without unhooking it from the ignition module (Splice it). Connect the - of the tantalum to a 2.2K resistor. The other end of the 2.2k will go to chassis ground later. Start the bike, hook up your timing light and note the timing. Ground the 2.2k resistor to the chassis and note your new timing. You may need to get some RPM into it before you will see a change as the pickup doesn't produce much voltage at idle. (I assume this is a reluctor pickup on your bike)
    I am sure your final product will use a different component value for the amount of retard you need·but this is a good start. If this works, I can direct you further.
    I have done this on my '81·Corvette and a simple retard of the timing with this method really knocks the wind out of the 500+hp motor.
  • kjennejohnkjennejohn Posts: 171
    edited 2008-06-02 06:38
    There is a forum member here named Parsko who has done considerable ignition control work and experimentation on bikes. Perhaps you can do a search (I just found tons of posts) on his name and find an email address or do a PM to contact him.
    Luck!
    kenjj
    edited 2008-06-06 12:17
    Hi Eric that should work fill the capacitor to slow down the hitting of the scr. How can we turn this on or off with a giving rpm or rate of change?
    Look at the Clare LCA110. Digikey has them and it should work fine.
