BS2 output current value
I would like to find out the current value output from BS2, eg. P0, P1, etc.
I am using BS2 to trigger the gate of a power mosfet, can I connect directly to the gate of the mosfet?
The BS2 uses a Microchip PIC microprocessor and you should download (from Microchip) and read the datasheet for the 16F57. You'll see the maximum output current for a single high I/O pin is 20mA. There are other limits for groups of 8 pins and for the entire device.
The BS2 can output up to 20 mA on a single I/O pin (any higher and the pin's I/O driver burns out), but 40 mA max for ALL I/O pins (any higher and the chip itself overheats).
