Strings and pointers
I am working on a project right now which uses a lot of strings. I just run into some trouble because strings are getting overwriten by other strings (this is at least what I think)
I decided to write a little program to understand how spin allocates memory for strings.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
LCD : "LCD_16x2_8bit"
VAR
byte text,text1
PUB main
text:=STRING("0123456789")
text1:=STRING("9876543210")
LCD.START
LCD.MOVEDEC(1,1,@text) ' displays decimal value at position x=1 / y=1 on LCD
LCD.MOVEDEC(1,2,@text1) ' displays decimal value at position x=1 / y=2 on LCD
LCD.MOVESTR(5,1,text) ' displays string at position x=5 / y=1 on LCD
LCD.MOVESTR(5,2,text1) ' displays string at position x=5 / y=2 on LCD
On my LCD I get the following result:
684 0123456789
685 9876543210
The string "text" points to address 684 and "text1" points to address 685 in the memory.
My question shouldn't "text1" overwrite "text"?
CON
OBJ
VAR
byte text,text1
PUB main
LCD.START
684 0123456789
685 9876543210
text and text1 are actually pointers. Therefore, they should be words and not bytes. Fortunately, since this program is short this isn't causing a problem yet. The string function returns the address of the zero terminated string passed to it. If you want to see what the addresses are use LCD.MOVEDEC(1,1,text) instead. The @text is giving you the location of the pointer, not the location of what the pointer is pointing to.
I however have another question about strings and memory allocation. In the following code I set the string a with different values. Then I display the propellers memory from address 1 to 300.
CON
OBJ
text : "vga_text"
VAR
WORD a
PUB start | i,c
a:=STRING("ABC")
a:=STRING("ABCD")
a:=STRING("ABCDE")
a:=STRING("ABCDEF")
a:=STRING("ABCDEFG")
a:=STRING("ABCDEFGH")
a:=STRING("ABC")
a:=STRING("ABCD")
a:=STRING("ABCDE")
a:=STRING("ABCDEF")
text.start(16)
repeat i from 0 to 300
c:=BYTE
if (c>$0D)
text.out(c)
The propellers adds every string into the memory. For example at address 130 I have "ABC" at address 134 I have "ABCD" and so on.
I wrote another program which has the problem that strings are getting overwriten. I am using large arrays and new values are getting assigned to the array many times.
If I assign in the above program a new value to a lets say 1000 times will the propeller not run out of memory? If yes what can I do about it.
I hope I explained my problem in an understandable way. English is my second language...
I think that's a view / use of terminology you should get away from. The variable 'a' isn't a "string" it's a pointer to what happens to be a string as stevenmess2004 said earlier.
Once it's understood as a pointer not "a string" it becomes much easier to understand that altering 'a' doesn't alter the string pointed to, only alters where 'a' points to.
Hippy: I am sorry for using the wrong tems. I new to the propeller and I am learning.
