Basic Stamp Basic Input Output System
I don't know if i would call it a operating system or a BIOS? or it even works! ( I don't have a Basic Stamp... Yet
Maybe it will work.
Specs:
Uses 84% of EEPROM
can make any pin "HIGH" or "LOW" and even "PULSOUT"
Post Edited (Matthew Burmeister) : 5/6/2008 5:43:57 PM GMT
)Maybe it will work.
Specs:
Uses 84% of EEPROM
' {$STAMP BS2}
' {$PBASIC 2.5}
'BSBIOS
'Copyright 2008 matthew burmeister
'BSBIOS Version 0.01 beta
'BSBIOS sets up here
command VAR Nib
highpin VAR Nib
lowpin VAR Nib
dummyvar VAR Bit
pulsoutpin VAR Nib
error VAR Nib
pulsouttime VAR Word
pausetime VAR Word
'BSBIOS first message and version command
version:
DEBUG "version 0.01 beta"
DEBUG "MBBIOS"
DEBUG "Welcome to the BSBIOS"
DEBUG "OR Basic Stamp Basic Input Output System"
'Display the commands the user can use
commands:
DEBUG "========================================="
DEBUG "1 - Make a pin 'HIGH'"
DEBUG "2 - Make a pin 'LOW'"
DEBUG "3 -'PULSOUT' on a pin"
DEBUG "4 - Display Help"
DEBUG "5 - Clear screen"
DEBUG "6 - Display Version"
DEBUG "7 - Exit BSBIOS"
'Get what command the user wants to execute
DEBUGIN command
IF command = "1" THEN GOTO makehigh:
IF command = "2" THEN GOTO makelow:
IF command = "3" THEN GOTO psout:
IF command = "4" THEN GOTO help:
IF command = "6" THEN END
IF command = "5" THEN GOTO clear:
IF command = "7" THEN GOTO version:
DEBUG CLS
error = 2
GOTO errors:
makehigh:
DEBUG CLS
DEBUG "What pin do you want to make 'HIGH'?"
DEBUGIN highpin
IF highpin < 15 THEN error = 1
IF highpin < 15 THEN GOTO errors:
HIGH HIGHpin
DEBUG "the pin has been made 'HIGH'"
GOTO commands:
makelow:
DEBUG CLS
DEBUG "What pin do you want to make 'LOW'?"
DEBUGIN lowpin
IF lowpin < 15 THEN error = 1
IF lowpin < 15 THEN GOSUB errors:
LOW lowpin
DEBUG "The pin has been made 'LOW'"
GOTO commands:
clear:
'Clear the DEBUG screen
DEBUG CLS
GOTO commands:
psout:
'Pulse out on given pin
DEBUG "What pin do you want to PULSOUT on?"
DEBUGIN pulsoutpin
error = 1
IF pulsoutpin < 15 THEN GOTO errors:
DEBUG "Whats is the pulse width?"
DEBUGIN pulsouttime
DEBUG "And how long will the Basic Stamp Pulse Out?"
DEBUGIN pausetime
PULSOUT pulsoutpin, pulsouttime
PAUSE pausetime
help:
DEBUG "MBBIOS HELP"
DEBUG "=========================================="
DEBUG "High - This command makes a pin 'HIGH'"
DEBUG "Low - This command makes a pin 'LOW'"
DEBUG "PULSOUT - This command makes the Stamp Pulse out on a given pin"
DEBUG "Hit enter to return to the menu"
DEBUGIN dummyvar
GOTO commands:
errors:
IF error = 1 THEN DEBUG "BSBIOS ERROR - Check pin number"
IF error = 2 THEN DEBUG "BSBIOS ERROR - Check Command"
'Reset all vars
error = 0
lowpin = 0
highpin = 0
pulsoutpin = 0
pulsouttime = 0
command = 0
'Asks if the user is ready to go back to the BSBIOS menu
DEBUG "Hit enter to return to the BSBIOS menu"
DEBUGIN dummyvar
GOTO commands:
