Basic Stamp 2 with SensComp 6500
Hi, i'm currently on a project to connect SensComp 6500 ranging module ultrasonic sensors with Basic Stamp 2 which will be interface with LabView.. So far i have managed to obtain data from one ultrasonic sensor.. Below is the source code used:
' {$STAMP BS2}
dist VAR Word ' working variable for distance calculation
ECHO CON 15 ' sonar module echo detection output
INIT CON 14 ' sonar module control input ' 1 starts a measurement ' 0 resets the module
settle CON 1
delay CON 20
convfac CON 29
offset CON 700
loop:
GOSUB sr_sonar
DEBUG DEC dist,CR
PAUSE delay
GOTO loop
sr_sonar:
HIGH INIT
PAUSE settle ' be certain that ECHO is low
RCTIME ECHO,0,dist ' wait for ECHO to go high
LOW INIT ' reset module
dist=(dist+offset)/convfac
RETURN
I was wondering is there any way i can obtain data from 5 ultrasonic sensors instead of only 1??· DO u think i need to make changes in the above source code which will be load into the BS2 through Stamp Editor· or· by making changes to the LabView?· Please reply asap.. Thanks...
' {$STAMP BS2}
settle CON 1
delay CON 20
convfac CON 29
offset CON 700
loop:
GOSUB sr_sonar
DEBUG DEC dist,CR
PAUSE delay
GOTO loop
sr_sonar:
HIGH INIT
RETURN
BS are single task, always thing that you do one thing folowing the other.
Hope to Help
Amaral
- Stephen
