How to read Signal Strength From 433 Receiver (HELP)
····· RSSI pin is received signal strength indicator. This line will supply an analog voltage that is proportional to the strength of the received signal. This is what the documentation says but does not show how to read this or use it with a BS2. Can someone help me out and give me a code example and schematic if needed?
Post Edited (kenwtn) : 5/6/2008 1:25:44 AM GMT
- Stephen
