Robotic exoskeleton
In the future, I am planning on creating an Exoskeleton-like suit (no not Iron Man) to help me work with heavy materials.
Plan so far:
Linear Actuators from http://servocity.com/html/12v_linear_actuators.html
Aluminum frame
12v SLA battery
3 actuators per arm
2 actuators per leg
A few questions:
1. What would be better to measure the angle my arm is at, a potentiometer or a bend sensor?
2. Could a linear actuator be controlled by the Motor Mind B?
3. How do you program the MMB?
Thanks!
Post Edited (curious_roboticist) : 5/6/2008 12:55:49 AM GMT
Plan so far:
Aluminum frame
12v SLA battery
3 actuators per arm
2 actuators per leg
A few questions:
Thanks!
· Finally, there have been a couple of contests for exoskeleton weightlifting. You might look at these for inspiration.
-phar
- Stephen
Whit+
theres a few different ideas.. a standard pot, a linear pot. and even a bit of fibre optics used to sense bends..
take a small bit of fiber, a led at one end, sensor at the other..
at the middle of the fiber, sand the fiber it self some..
then take the led, give it some juice, not a lot, then go and check the output of the sensor.. when you bend the fiber, it should reduce the output some.. not sure by how much. depends on how much light is lost to the abrasion of the fiber at the bend..
This stuff will be heavy, and that means you MUST have good support(read: strong actuators) in the ankle joints.
They will need to be able to tip the blade of the foot back and forth, side to side, and to swivel it somewhat.
Unless you leave a lot of slack inside the skeleton so that your limbs can move, positional sensors won't be much use. You will need pressure sensors.
you'll also need 'outside' pressure sensors.
Low pressure inside = slow movement.
High pressure on inside + no pressure outside = fast movement
High pressure inside + high pressure outside = Slow movement, high torque(lifting/pushing)
No pressure inside + High outside = Keep it powered to lock the joints. (Holding)
You may also want pressure sensors in the foot blades to adjust the ankle joints, possibly a gyro to help keep your balance. (This kind of stuff is heavy, after all, and falling flat on your back isn't the way to impress your buddies
Don't visit my new website...
-I was not intending to augment the wrist. However, that may come later.
-These are the actuators I was planning on using. However, they only move at 0.5 inches per second at full load(115 lbs.) If someone can find a more powerful and/or faster actuator for a similar price, please let me know.
-How long would the signals take to be processed and sent to the actuators? Even with a small amount of lag, the suit could feel like moving through water.
-robotshop.ca sells actuators that lift 400 pounds! However, they only move at 0.5 inches per second with no load. Could I hack them safely to make them turn faster?
-What kind of pressure sensors do you suggest, and where would be the best place to put them?
Post Edited (curious_roboticist) : 5/7/2008 12:47:57 AM GMT
-phar
Geared motors, steppers, hydraulics...
-phar
Current Projects:
Robot Control Via Skype API - Dev Stage(50% Complete) - Total(25%)
Robot Localization Via Xbee's - Research Stage
IR Tracking with Propeller - Research Stage
On a robot that might be useful, particularly on startup, but on an exo-skeleton, the computer doesn't need to know the position of most limbs, even at startup.
It's only there to assist the wearer by applying extra force when he moves his limbs.
