1/2 H Bridge power & ground
Using a BS2 on a BOE, I am trying to duplicate the 1/2 H Bridge circuit shown at
http://www.mcmanis.com/chuck/robotics/tutorial/h-bridge/bjt_analysis.html
I'm puzzled as to where the ground symbol on the top left optoisolator output transistor emitter hooks to.· Does it hook to the BOE Vss, or TP4, Battery Negative, or both?· By the same token, does the V+ on the collector of the optoisolator lower transistor go to Vdd, TP1 Battery Positive, or both?· For that matter, does this circuit need a common ground, or a common V+?· Can't be both, I don't think the Stamp would appreciate that with a 12 volt battery for the motor.· I'm new to using both an NPN and a PNP in the same circuit, so a bit confused as to what will work here, and not release any smoke.
Thanks for any help or insight you can give me on this one.
Charlie
Charlie
