Does anyone know how to change functions of the CMUcam without using the pushbuttons or can it be done? I would like to be able to have the track color function run at certain times. Thanks in·advance.
I assume you have the boebot version and a bs2, but even if you don't, all the camera versions have the same basic commands.
If you are using the bs2, you probably have the camera in poll mode if you followed the examples, so the camera will be idle anyway.
If not, to set the CMUcam into idle mode send the command string \r (Carriage return, ascii decimal 13)
When you want to track the same color again, just send TC
to track a different color, read the details of sending a color packet to the camera under the TC command explanation.
Then read it. ALL the commands. There's a suggested exercise of copying the auto servo tracking function by sending commands to the camera. If you can duplicate that, you're a long way towards mastering the device,
I'd suggest you get the entire CMUcan manual at
www.seattlerobotics.com/CMUcamManualv15A.pdf
