Wireless Sender/Receiver?
I'm connecting my Javelin to pretty everything in my house, and I now want him to open the door with I come back from the job.
I'm already able to connect it to the door, and open the door, but I'm looking for something that I will be able to always carry on me, and that Javelin can see. When I will walk the stairs, I will pass near a receiver, which will see my transmiter, and unlock the door for 10 secondes. So I will not need a key anymore.
My concerns is "how to find a transmiter and a receiver like those one"? I don't want to have to activate anything to start the transmiter. Also, will be great if I can have more than one transmiter, with IDs which will allow me to manage the access.
For for any hints you will be able to give me.
JM
JM
Look like the solution will be to use RFID components, but the transmiter need to be about 2 inches of the receiver, which is not possible for me.
http://www.parallax.com/Store/Accessories/Communication/tabid/161/CategoryID/36/List/0/Level/a/ProductID/503/Default.aspx?SortField=ProductName,ProductName
http://www.parallax.com/Store/Accessories/Communication/tabid/161/CategoryID/36/List/0/Level/a/ProductID/114/Default.aspx?SortField=ProductName,ProductName
But look also like something using the same technologie will allow me to do that. On right corner of page 3 of http://www.parallax.com/Portals/0/Downloads/docs/cols/NVRFID.pdf seems that it's possible to receive up to 1m. Which will be perfect for me.
I was able to find some receiver with 2m capabilities (http://www.superrfid.net/english/PRODUCT/view.asp?id=410), but seems that it's not the same frequency as Parallax tags, so will no work.
Still looking for some ideas...
JM
Thanks for the suggestion. That's a good idea.
My only concern is with the rang. Technical specifications indicate 300 feet range. So that mean even when I will be inside the house, the Javelin will see the cell phone, and try to open the door.
Is there a way to limit this range? Or if there a way to know the distance between the cell phone and the receiver?
I took a look at EB500 user manual, but was not able to figure how to do so.
Thanks for your help,
JM
So I will get one, and try [noparse];)[/noparse]
Thanks again for you help.
Jean-Marc
