EMI and regulator Question
Here is a shot from Diptrace showing a board I'm putting together. My problem is that the board will be mounted to the back of a 5" LCD screen that, naturally has·a Transformer on it for the Backlight. I have positioned my digital components as far away as possible, and used the area closest to it for my regulator and Heatsink. I am planning on having the area under my heat sink, on both sides of the board, copper poured.
What rail, or no rail at all, should I connect the Thermals to in this case to keep EMI out of my Power supply!
All the components are not on the pic, but the area to the upper right is as populated as it is going to get.
Paul Baker
It may be no big deal with the propeller, but the first prototype of this project had a max1270 ADC chip setting approxamately where that regulator is an it was completly incoherent until I moved it away down and to the left!
Else I can just isolate the copper!
Paul Baker
