Serial Protocol
There is a device I want the Prop to talk to bi directionally
it's spec sheet says it is 8 bits, odd par, 1 stop, least sig bit first.
I am thinking this is not standard for the Full Duplex object.
I don't have the device yet, but am curious if this is going to be something that can be worked around with some tricks.
Thanks for any insight on this.
Both could be done with Spin, but it would be easier to do this in the assembly portion of the FullDuplexSerial driver because the Propeller has built-in hardware for parity checking/generation, but Spin doesn't have an equivalent operation.
I looked at the object's assembly section, not knowing the language obviously I don't understand what would need to be changed in there, but when the parts come in I will experiment with it and post back to get some ideas on how to implement the assembly revision.
A second question has come up. There will be cases where there are two of the devices connected to the Prop. Data from one device will ned to be transfered by the Prop to the other and vice versa.
Is the best way to manage that data to put an extra 256k eeprom on board as a temp storage? Read one device and park the 30400 bytes on it, then transfer to the other device? it seems rather tricky to access one device in upload mode and the other device in download mode so that the Prop could manage the data in small chunks.
Post Edited (Originator) : 5/4/2008 7:47:19 PM GMT
EEPROMs wear out eventually. It takes a lot of writes to wear them out (100000+), but it can be done in a month or so if you write to the same location once a second. There are other devices that can be used for buffering data. Each has its advantages and disadvantages
There is already a VNC1L connected to a USB drive, so that could be used as well for a temp storage. This particular process of transferring the data from one to the other will never come close to 100k operations.
At a slow enough baud I think the EEPROM or USB drive would write fast enough. Since both devices are connected to the Prop on separate Tx and Rx pins, another thought is to simply pass through the data, set one in transmit and one to receive, and let the data pass through the Prop one byte at a time, bypassing any temp storage medium.
I think this is the best solution if it will work, let the Prop tell one device to get ready to receive, then tell the other device to Transmit, then set the pins to route the data as shown above.
No temp storage needed.
Post Edited (Originator) : 5/5/2008 6:54:02 AM GMT
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
I just received news from their tech. Among other blatant mistakes in the PDF of the devices, the actual data that needs to be shared is 938 bytes, not 30400 bytes as originally understood from the data sheet.
