SD card hookup question
OK, I have qty 10 of the 10K ohm resistors in the house and I am trying to bread board up the SD card using an old floppy drive cable. if I had two more I could run two in series for each pull-up line to get teh 20K...that much I understand. Am I going to hurt anything by having the 10K ohm resistors instead of the 20K ohm resistors? I can't quite figure out if I can use some other resistor to supply all 6 of the 10K resistors and get the same effect?
Thanks all for your patience...I will continue reading online to see if I can figure this out myself.
had it work fine. (Take a look at the Cookbook link below)
On the other hand, I suspect that 10K resistors would be just fine too,
and in fact my first design incorporated back-to-back 10K resistors
to obtain the 20K value.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
http://ucontroller.com/documentation/SDCardDoc.html
I just wired it off instruction on oldbitcollector's page. (a wonderful resource)
Awesome.
Now i need more than one keyboard so I don't have to keep switching b/w computers hehehehe.
(They always have them around her for $1.00 [noparse]:)[/noparse]
Then give PropDOS or PropBASH a "spin" -- SD is one of the neatest addons yet.
OBC
Need a part? Got spare electronics? - The Electronics Exchange
